50ccm in Vollendung.
Verfasst: So 8. Jun 2014, 08:40
Beim stöbern in fremden Foren bin ich auf einen tollen Thread gestossen, den ich Aufgrund der Forenregeln nicht verlinken, aber kopieren werde.
Viel spass
Suzuki RP 68... 50ccm, 3 Zylinder, 380PS aus einem Liter Hubraum..... vor 40 Jahren
2Zylinder liegend, einer stehend, oben auch die Ölversorgung zu erkennen, die zentral alle wichtigen Teile mit Öl versorgte.
14 Gänge.... Da scheißt dir ne Fliege auf den Helm, und du musst 2 Gänge runterschalten
Zylinder, die du dir auch in die Hosentasche stecken kannst, 16,6 ccm pro Zylinder, aber zusammen 19 PS am Rad bei 20000upm
Honda hat auchmal was tolles gebracht:
50 cc RC116 Difference between the RC115 and the RC116 is a new bore and stroke, now being 35.5 x 25.14 mm. Power output is 16 bhp at 21,500 rpm. This means 320 bhp per litre and a Pme of nearly 16 kg/cm2 ! As regards bhp per litre, this is a figure that has never been surpassed by any naturally aspirated four stroke engine, and even today's formula 1 cars with their special fuel brews cannot hold a candle to it. I know this is not a totally fair comparison, but it gives an idea of the level of four stroke technology nearly 40 years ago. This engine is the most advanced of all the Honda engines. Red line at 22,500 rpm. Carburettors have flat slides. The gearbox contains a nine speed cluster. Dry weight of the bike is 58 kg. The piston pin has a diameter of 9 mm and weighs 6 g. The inlet valve head is 13 mm, the exhaust valve head is 11.5 mm, and the stems are 3.5 mm diameter. Weight of the exhaust valve: 6 g.
Sabber...
Viel spass
Sabber...
