Geile Technikbilder/Projekte
Greenhorn
Beitrag von Greenhorn »
...ihr wollt es doch auch!
Sexy Technik in Perfektion zum Träumen & Verlieben -> hier rein.
Egal ob Autoteile, ganze Motoren, Motorräder etc. hier könnt ihr alles posten was technisch und/oder optisch einfach nur geil ist.
Ich poste hier ein paar Bilder aus einem Thread eines anderen Forums:
Spoiler für Porno aus Stahl :P:
Spoiler für Frauenauto? Naja...:
Greenhorn
Re: Geile Technikbilder/Projekte
Sorry for DP, aber habe Angst dass ich zuviele Zeichen brauche.
Spoiler für Einfach nur krank...:
Every now and then I come across something truly impressive. This represents some of the work of Extreme Tuners in Athens, Greece, and the name is no joke. Pushing limits requires funds and skill, and these guys have both. All they do is build and tune engines. The entire lengthy discussion can be found here (http://forums.evolutionm.net/evo-dyn...ne-2007-a.html), but unless you feel like reading quite a few pages of posts, I'll post the highlights here.
FWIW, this is some of what they've done:
2006 - N/A ford cosworth 4cylinder 16v engine 119cui: 416hp -11,900rpms
2007 - Ford cosworth 4cylinder 16v Turbo engine 120cui: 1280hp 47psi (custom triple ball bearing 80mm turbo 119lbs/min)
2007 – Mitsubishi Evo 8 4g63 4cylinder 16v Turbo engine: 1416hp – 57psi (custom quad ball bearing 82mm turbo 132lbs/min)
So, getting 700whp/L from 2.0L @ 8500rpm is no small feat, but what do you need if you get bored and want to shoot for 2000whp?
Cast Garrett compressor wheels (right) tend to come apart above 50 psi. CNC billet aluminum wheels (middle) are stronger, but why not be different and use your own CNC billet titanium (left) compressor?
You'll need a turbo big enough for the job, which in this case is a 108mm twinscroll T4 turbo, with custom quad ball bearing CHRA and 100psi capability.
To get enough airflow at 12,000rpm(!) to get the job done, you'll need a skillfully ported head, complete with titanium valves and copper-beryllium valve seats:
And you're going to need a set of camshafts to handle the rpm and withstand tremendous ramp pressures, so why not a set of hollow titanium billets with DLC at only 234 grams each?
And since there is no aftermarket rod up to the task, just ask for a set of billet mmcs-titanium connecting rods at 286g each. Rod/Stroke ratio is 2.07:
For pistons, a set of custom beryllium pistons with DLC fits the bill, and since methanol is the fuel, 13:1 SCR is fine:
A strong piston pin is needed as well:
Toss in a custom titanium billet crank:
A set of 9000cc/min injectors:
And since a factory 4G63 block probably wouldn't hold up, just CNC machine your own from billet aluminum:
No head gasket is used:
And to put all that power to the gearbox, one needs a suitable multiplate clutch:
Yes, it is smaller than a cam gear:
Ich werde versuchen noch mehr von diesem Projekt aufzutreiben ;)
Spoiler für Noch ein kleines Leckerchen, wer erratet was es ist?:
Spoiler für Auch Schweissnähte können geil sein:
COD_CJ_
Beitrag von COD_CJ_ »
Geile Bilder, echt !! :bravo: :D
Werd da devinitiv regelmässig mitlesen^^
Ah und das 2. letzte Bild, V8 schonmal ganz geil :^^ :thumbup die direkte Nitroeinspritzung naja wer's wirklich noch nötig hat :? sieht aber sehr schön aus !
Nothing beats an Astronaut
Greenhorn
Meeep, wrong :D
Ist eine Wasser/Meth Einspritzung :XD
COD_CJ_
:XD Hahahaha shit XD naja nah drann^^
I.wie kommt mir da grade so ein gedanke.... Mofa....Wasser/Meth-Einspritzung....Mofa+Wasser/Meth-Einspritzung = :chop: 8)
COD_CJ_
:lol: :bravo: Naja ich trag dann meine Motorradhose, dann bin ich 100% geschützt ^^ und sonst, gibt's halt 1 Umweltverschmutzer weniger :hi:
Greenhorn
Hier noch ein geiles Projekt:
puchlover
Beitrag von puchlover »
Element Competition Catch Can.jpg (312 KiB) 8783 mal betrachtet
Zylinderhuhn
Beitrag von Zylinderhuhn »
Hauptsache vergoldetes Automatengetriebe :lol: :thumbup
Der Thread ist aber super!! Sehr geile Bilder..!
Zylinderhuhn
Greenhorn
Lieber ordentliche Arbeit und ein bissel Dreck im Motorraum als so ein Goldgeblinke :mrgreen:
Aber ist Geschmackssache, wenn BlingBling, dann schönes Chrom, aber Gold :?
zylinder_kopf
Beitrag von zylinder_kopf »
So ein Geiler Thread darf nicht vergessen werden :XD
Theorie ist,
wenn man alles weiß,
aber nichts funktioniert.
Praxis ist,
wenn alles funktioniert
und keiner weiß warum.
Nichts funktioniert
Zylinderhuhn
Hut ab vor der Arbeit, aber trotzdem schade dass das Teil nur mit Druckluft läuft :o
Ronin
Beitrag von Ronin »
2W Laser:
interessanter motor, auslass ist nebenbei oben neben der kerze
Werner, in meiner Kindheit, hat mir auf jeden Fall nicht geschadet....
Schaut euch mal das Video an. N echtes Meiistääweerk! :p
Einfach nur geil :XD Ich dreh noch durch :chop:
Ronin
Beitrag von Ronin »
Jetzt ist der Thread fast auf die 2. Seite gerutscht...
Spoiler für Twin Turbo einfach immer wieder schön anzusehen:
Ronin
Beitrag von Ronin »
Gefunden dank gluglu81's Playboy Heftchen :wink:
Mehr Infos gibts da:
http://www.mopedarmy.com/forums/read.ph ... 56,3488956
